Ecosys m2550idn printing slow
  • BabblingXombie
    • Jun 2015
    • 32
    Ecosys m2550idn printing slow on windows 10 computers
    Ive tried the latest KX & XPS Drivers no luck
    It does it on 4 computers
    Any help would be greatly appreciated
    Re: Ecosys m2550idn printing slow
    is it setup on a WSD PORT? not driver
    what kinda network?
    • Firthy
      • Apr 2019
      • 20
      what kinda network?
      Phil is on the money I reckon.
      If not wsd to a continuous ping test to copier and see if latency is high that could a tell tale sign its network
      • BabblingXombie
        • Jun 2015
        • 32
        No not wsd its setup with a driver
        • BabblingXombie
          • Jun 2015
          • 32
          LAN Network
          • JR2ALTA
            • Feb 2010
            • 2028
            Latest firmware? Did you test off-network with laptop? Is machine set to Quick Recovery vs Energy Save?
            • BabblingXombie
              • Jun 2015
              • 32
              Can someone get me the latest firmware i cant login to kdaconnect right now for some reason?
              • diedux
                • Jan 2017
                • 124
                I had somewhat similar situation with Kyo/TA/Utax. I used slower color KX (25ppm) driver for entire fleet. So b&w 40ppm machines printed at 25ppm speed. After changing a printer model from 25ppm to 40ppm model in driver, 40ppm machines started to print at regular speed.
                • ntbann
                  • Jan 2012
                  • 623
                  We usualy disable WSD at the machine because windows 10 likes to load WSD printers by itself.
                  • copier tech
                    • 8105
                    Check the driver setting port tab does it show IP not WSD?
                    We can supply the latest firmware if you wanted to try that.
                    • BabblingXombie
                      • Jun 2015
                      • 32
                      I installed latest firmware today. the printing still seems a little slow.
                      • copier tech
                        • 8105
                        If you are sure your printing over IP not WSD could simply be a slow network environment.
                        Also this model is a Micky mouse printer you cant expect lightning speed especially printing pdf files.
                        • diedux
                          • Jan 2017
                          • 124
                          Actually, you never told us which parts of printing are slow. Is it rendering part, spooling part or actual print?
                          "Slow printing" is from an end-user perspective. So if you want more help, be more specific.
