7052ci all solid cyan
  • toddanderson
    • Dec 2005
    • 236
    I have a 7052ci that has solid cyan on every copy,
    No c-codes and replace main charge related things- new drum unit, charge roller , main hi voltage unit, engine pwb
    I am thinking it could be a laser problem- can anyone tell me how to test or trouble shoot a laser issue.
    just not sure what to try next
    thanks for the help
  • kyotechnz
    • Mar 2019
    • 145
    Re: 7052ci all solid cyan
    All the laser units are the same so just swap the cyan unit for one of the others. If the problem moves you know you are right.
    • GIUBOSS
      • 1435
      have you made the necessary adjustments after replacing the parts? also check the firmware if updated.
      • sparkycivic
        • Apr 2017
        • 348
        have u tried a new developer yet?
          +1 on dev unit...
          OP never mentioned:
          total pages
          life on PM parts
          did this happen AFTER a service call?
          if so what was done on the call?
          OEM Genuine Toners/Drum or compat?
          what are the bias reading on the different drum/toner/dev?
          have you CLEANED the machine?
          • toddanderson
            • Dec 2005
            • 236
            I found the contact spring out of place on the HV pwb, resolved the issue
            thanks for the help
