taskalfa 5500i paper jam
  • Gab
    • Aug 2015
    • 655
    Papaer jam at first and third cassete. . At the beggining had problem first cassete (it makes copies but have had paper jams too frequently) and later 3rd too (it doesn't even pulls paper).
    Machine made about 160k copies. I cleaned feed rollers with no result.
    I am not familiar with kyocera machines . Once i had same problem with a KM 4035 and a technician told me to run a program and after that it was ok! Is there anything similar to this machine? Else?
  • kuby
    • Oct 2007
    • 1371
    Re: taskalfa 5500i paper jam
    Paper feed rollers? Cassettes set right?
      • 29359
      What's the jam code?
      If you cleaned feed tires and it keeps misfeeding replace the feed tires
        • 22927
        When you come up with a jam code I'll give it some thought. =^..^=
