Yellow back ground
  • ntbann
    • Jan 2012
    • 632
    Yellow back ground
    I have a TA4002i that 3 weeks ago had yellow back grounded when scanning to SMB through the doc feeder only. From the glass was fine. Re calibrated scanner and the problem was gone. Its back now. Anyone seen this? Thanks in advance.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Yellow back ground
    First thing I'd try is updating the firmware.
      • 22994
      You may need to do a CCD calibration with the charts. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2032
        Do they do a lot of copying? Any background then? There's an issue with intermittent background through ADF only and i am wondering if it shows up yellow on your color scans instead of grey while copying.
        https://www.copytechnet.com/forums/k...t=#post1241372
