fs-4000
    • 30303
    fs-4000
    Multi sheet feeding using 3 hole punched paper.
    any suggestions?
    Have already changed out retard roller and updated firmware and media type is set to prepunched
    • 23009
    Just riffle the paper really well. That's all you can do. =^..^=
    • 10871087
      • Jan 2005
      • 1062
      Homemade 3-hole or good stuff punched right out of the wrapper? How consistent is the jam?
      Try it in the Multi-purpose tray, similar jamming from two different paperfeed methods = shit paper.
      Either way go with Blackcat's classic but effective technique of "fan the crap out if it and see if it helps".
      Keep us posted
        • 30303
        multi feed
        fs-4000 with 2 trays
        bypass not an option
        customer runs 3000 sheets a day
        prepunched brand paper being used
        had a hp4200 and customer says hp never did it.
          • 23009
          You know how batches of paper can go. Two good, one bad.....
          You could try a different brand of pre-punched paper, just to prove the point that it isn't the machine. Give them 5 or 6 reams for free. Everybody likes free stuff, and if it convinces your customer it's a cheap fix. =^..^=
          • fitsy.13
            senior tech
            • 64
            any suggestions?
            change the torque limiter
