Registration roller Kyocera FS-4200 EcosysP4055DN
  • DeeMania
    • Feb 2020
    • 1
    Hi, tough question for you all. I have 3 machine's FS4200 and 2 P3055DN at a transport company. They only print CMR transportletters, the acid in these papers have thickenend the registration roller and now it makes a noise such as a pressure roller that has an flat side..How the ... can you replace these roller? thit they build the machine around the registration roller?
    Hope for some tips thxxx
  • sparkycivic
    • Apr 2017
    • 348
    Re: Registration roller Kyocera FS-4200 EcosysP4055DN
    This has been my impression.
    I haven't become brave or stupid enough to attempt registration roller removal in the field yet. One attempt on a cadaver yielded only certain death.
      • 23008
      Once you have the clutches off, you're close. That's as close as I've gotten. To get those clutches you'll have strip the right frame.
      Be prepared to change the bushings also. AFAIK there is no part number for those bushings. I dug through my miscellany to find replacements. =^..^=
      • granata
        • Jan 2012
        • 32
        I had a similar problem with a carbonless paper used by the customer on a utax 5030dn, the problem turned out to be the swollen transfer roller on one side due to the acid contained in the paper, give it a try
