taskalfa 3500i light image
  • Gab
    • Aug 2015
    • 671
    MAchine works fine for 2, 3 weeks and then light image. I execute U132 and it works fine for 2,3 weeks and then the same.
    I cleaned corona, optics with no result
    Machine is one of a load of second hand copiers (all counters under 200k copies) . Because i had a lot of toners from these machines not full i transfered toner from one cartridge to an other to fill it. Toner are genuin Can it be toner? Perhaps toner chips or something else?
  • avio2
    • Jul 2010
    • 150
    Re: taskalfa 3500i light image
    2-3 week but how many print?
    and tis not have corona but roller charge
    however try to change the toner with 1 new then the dv unit
    • GIUBOSS
      • 1435
      the chip does not lighten the image ... Check on the surface of the drum if a good image is formed (cutting the print) then the problem is in the transfer unit. Sometimes a bearing in the ends is damaged.
      • tsbservice
        Field tech
        • 8013
        Yeah basics troubleshooting, agree on with Italian fellow techs.
        Off topic:
        Italy keep fighting on 👍
        Our hearts and souls are with you.
