CS4052ci Fax
  • McCrazy
    • Feb 2020
    • 15
    CS4052ci Fax
    I have a cs4052 with 1000 sheet external finisher with fax. I have been through the manuals and menus on the web interface, and the machine itself, but I cannot find where to set the default output tray for incoming faxes. Have I missed it in the manual? Client would like for incoming faxes to print in the job separator (above the bridge unit), so that the faxes aren't mixed in with other print jobs in the DF-7100 tray.
  • marc
    • Feb 2010
    • 56
    Re: CS4052ci Fax
    try service mode U211
    • marc
      • Feb 2010
      • 56
      Re: CS4052ci Fax
      Here its.
      • mita
        • Sep 2010
        • 87
        Re: CS4052ci Fax
        It's set under the defaults for paper output (fax)
        • marc
          • Feb 2010
          • 56
          Re: CS4052ci Fax
          System menu-common Settings-paper output
          • KYO_OEM
            • Aug 2011
            • 727
            Re: CS4052ci Fax
            If still "old" FW installed you must enter Systemmenue/ "Quick Setup Wizard" for Fax.
            No other way out with "old" FW when i remember correctly.
