Question About Copying Secure Check on a 3252ci
  • Happy Copier
    • Mar 2019
    • 49
    I'm coming to you geniuses first because I figure you'd know the answer to this no problem. I have a customer who is interested in purchasing a 3252ci from my company (and I don't have access to it because it's being rented to another customer) and they want to know if it can copy secure checks. This is something I have not messed with much and don't really know how it works, but I have seen a machine refuse to do it.
    I appreciate any help, have a great day!
  • FrohnB
    • Jul 2017
    • 1919
    Re: Question About Copying Secure Check on a 3252ci
    With Ricoh machines, I know you have to Enlarge to 125% or Reduce to like 65%, otherwise it will just come out as a black sheet.
    This is true with money, checks, death certificates, etc.
    Omertà
    • JR2ALTA
      • Feb 2010
      • 2033
      I've found only black and white mode works not greyscale or auto color.
        • 23006
        I've had some success by covering the holograms with a sticky note. =^..^=
        • mincopier
          • Dec 2015
          • 289
          It is illegal to copy any checks, bank notes or passports. This is in the copyright laws.
          With that being said, the first thing that you are instructed to do when you get your passport is to make a copy. Microsoft was the same way. Their instructions would say to make a copy of the install disk and use the copy to install the software.
          Another option is to scan the check and then reprint it.
          • scottybbb
            • Dec 2010
            • 126
            I think the Reduce or Enlarge trick that was mentioned should work.
