Utax 2506ci jam code 0511
  • figaro
    • Jan 2011
    • 9
    [Jamming] Utax 2506ci jam code 0511
    Hi,
    Anybody had any success in resolving this jam 0511 code issue on cassette 1
    We have swapped primary feed units around, no luck.
    Did the necessary as per bulletin TB-48B and the machine was working for a few days.
    Did simulation 031, 032, 033 and tests were ok.
    Firmware is the latest.
    Reset machine 021 and 906 and no difference.
    Anything that we overlooking?
  • pascalb.
    • Aug 2016
    • 47
    Re: Utax 2506ci jam code 0511
    Hi ,
    - Does it work on cassette 2 in A4?
    - Have you tested with another paper?
    sometimes the paper is badly cut and takes several sheets.
    I have already met him.
    Kind regards
    Do not lament,
    do not mock,
    do not hate,
    but understand.
    • Tonerkiller
      • Oct 2012
      • 668
      The feed clutch may be bad.
      • figaro
        • Jan 2011
        • 9
        Originally posted by pascalb.
        Hi ,
        Kind regards
        Cassette 2 works 100%.
        We tried different paper with the same results.
        • figaro
          • Jan 2011
          • 9
          on inspection the clutch looks Ok...maybe we replace it with a new one and see.
          will get back to you on this.
          • avio2
            • Jul 2010
            • 150
            registration clutch
            • lanierboy
              • 149
              I would recommend that you change the paper feed drive assby as a complete unit.
