Re: Utax 2506ci jam code 0511
I would recommend that you change the paper feed drive assby as a complete unit.
We tried different paper with the same results.Leave a comment:
Hi ,
- Does it work on cassette 2 in A4?
- Have you tested with another paper?
sometimes the paper is badly cut and takes several sheets.
I have already met him.
Kind regards
Anybody had any success in resolving this jam 0511 code issue on cassette 1
We have swapped primary feed units around, no luck.
Did the necessary as per bulletin TB-48B and the machine was working for a few days.
Did simulation 031, 032, 033 and tests were ok.
Firmware is the latest.
Reset machine 021 and 906 and no difference.
Anything that we overlooking?
