Kyocera FS 2100 - Print Alignment Issue
  • insigniawales
    • 29
    [Misc] Kyocera FS 2100 - Print Alignment Issue
    Good Morning
    A Strange one - although I can see on previous models about Print Alignment where by the Image is printed at the top edge of the page. (i.e) the IMage is put on the paper to early. See examples attached,
    Stripped down and cleaned sensors (including paper registration sensor) - my thinking this has worn down potentially or misshaped
    Any help would be much appreciated - trying to catch up on workshop work in the COVID 19 lock down.
    KR
    R
    doc04194320200316093840.pdf
    doc04194220200316093832.pdf
    • 30310
    Re: Kyocera FS 2100 - Print Alignment Issue
    What happen to printer? Did you do any adjustments? You should never have to adjust margins once factory set.
    Paper skew is the only issue look for a stuck label in feed path etc.....
    • mita
      • Sep 2010
      • 87
      Try using fresh paper, as far as image registration the actuator can wear down over time and cause that and jamming. But I have mostly seen this on high volume printers. Is the image off by the same margin all the time? If it varies replace the clutches and retest, also what condition are the feed /sep rollers in?
        • 23009
        I agree on all points. At 1M images the registration flag will nearly be sheared off, the registration clutches rusting, and the registration bushings oval. =^..^=
