M3540idn with Under toned prints
  • Jedenco
    • 39
    [CQ] M3540idn with Under toned prints
    Hello,
    I'm working with a Kyocera M3540idn that has washed out print, looks undertone and this is a mono-component unit. We recently replaced the Maintenance kit (dev, drum fuser) and its using OEM toner. The service manual suggests High Voltage unit. I'm curious if anyone has had this issue and found a different resolution or it indeed was the High Voltage Unit? Any assistance is sincerely appreciated. Thanks!
  • scottybbb
    • Dec 2010
    • 126
    Re: M3540idn with Under toned prints
    There is a developer clutch on those units that can cause light print or no print. I would check that.
    • HenryT2
      • 962
      Check the print density to be sure it is set to 3 . Also check to be sure it is not in ECOPRINT mode .
      "The Serenity Prayer" . . .
      God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
