Taskalfa 5501i white pages
  • Gab
    • Aug 2015
    • 671
    I checked this second hand machine and it was ok . I transported to customer and copies are white.
    Tommorow i will check corona . Is there anything else i have to check?
  • Scott
    • 196
    Re: Taskalfa 5501i white pages
    Corona?
      • 23008
      The copies are white? The prints are white? Completely white ... or maybe just poor transfer. Or maybe poor developing? When you emergency stop the machine is there latent image on the drum?
      Where you there? =^..^=
      • Gab
        • Aug 2015
        • 671
        Completely white . As i had told you machine was tested and it was ok . I stored it one day in the car and next day delivered it . When i tested at the customer completely white image .
        • copydocinc
          • Mar 2015
          • 263
          You should answer the rest of blackcats questions.
          Does it print white? or only copy white? Try to print out a status report form the control panels counter button.
          Did you stop it in the middle of a copy to check the drum for and image on it that hasn't transferred?
