taskalfa 5500i DF
  • Gab
    • Aug 2015
    • 677
    taskalfa 5500i DF
    Can i use a 5500i Document feeder on 5501i ?
  • rvptor
    • Aug 2018
    • 19
    Re: taskalfa 5500i DF
    yes
    • Gab
      • Aug 2015
      • 677
      I tried to swap them ( i swaped a DP from working 5500i ) to a 5501i which dp was problematic ( when i put paper on it it recogniced them (green light on DP) , when i open a DP cover it recognized it ) but when i try to copy from DP message .. copying appears and blocks. If during this time i open a DP cover , it copies but from glass and paper jam message) . Now i suspect it's the PWB ISC i checked part list and PWB from 5501 has different code from 5500. Can i swap them?
      Or if the problem is not PWB any idea?
        • 23010
        Did you re-load the firmware?
        ANY time you install a different board you must re-load firmware so that there are compatible levels of firmware. =^..^=
        • nathicana
          • Aug 2008
          • 335
          Try running the document processor independently in mode u203
          Does the DP function during scan and send?
            • 23010
            Just to clarify: Kyocera products are unique in defining a "DF" as a document finisher, and a "DP" as a document processor. =^..^=
