Kyocera ecosys M5526cdw color smear
  • cepheus
    • Apr 2020
    • 2
    I'm having an issue with this printer. Whenever the printer is set to print in black and white, there is no problem. However, when it is set to print in color, a full text page or even a blank page will print with an uneven yellow smear all over the page (see picture). The backside of the page is normal white.
    So far I've replaced the toner and checked inside to see if anything is wrong. Frankly I don't know what a printer in a normal state is supposed to look like from the inside. I saw some yellow toner on the transfer belt and sticking to the PCB above it. The transfer roller also has a yellowish hue which made me think that the toner moved into places where it doesn't belong, yet the backside of the page is white. Any ideas on how to resolve this issue?
  • davel
    • Oct 2011
    • 1109
    Re: Kyocera ecosys M5526cdw color smear
    Call a Kyocera trained technician.
    • GIUBOSS
      • 1437
      IMG_5278.jpgIMG_5290.jpgIMG_5291.jpgIMG_5295.jpg[/CITAZIONE]
      I agree with
      Davel. The problem is with the drum section or yellow development, but to access it, we need to get the drum set out and see it. Are you a technician? This machine is not '' replace maintenance kits yourself ''
      • GIUBOSS
        • 1437
        [ATTACH=CONFIG]45419[/ATTACH][ATTACH=CONFIG]45420[/ATTACH][ATTACH=CONFIG]45421[/ATTACH][ATTACH=CONFIG]45422[/ATTACH]
        I agree with
        • cepheus
          • Apr 2020
          • 2
          • Copierstud
            • Nov 2019
            • 38
            OEM toner?
            • copiertec
              • Jan 2016
              • 2222
              Most likely the company you bought it from would cover it under warranty, if it is still applicable and you have not installed aftermarket toners. We deal with some clients who buy from an internet provider that provides free shipping (Scamazon), but do not provide installation with that product or having a trained person teach them how to use it, once it is installed, but, most of all, good luck trying to get them to warranty your product! If you bought it from a local service provider and you did not install aftermarket toners (to try and save money!) I am sure there should be some sort of warranty (most are 1 to 3 years).
              • jmaister
                certified scrub
                • Aug 2010
                • 755
                that's not just something smearing, its something failed... Most likely yellow drum's cleaning portion is gone or anything to do with transporting yellow toner, that's quite a bit of volume...
                or the waste port is plugged, backed up, and VOMITED.
                Idling colour developers are not healthy developers.
                • jonh
                  • Mar 2024
                  • 1
                  May I ask if the waste port is part of the drum assembly, developer assembly or ???
                  Thanks.
