TA 5500i
  • Gab
    • Aug 2015
    • 671
    TA 5500i
    When i send to print from a PDF file it prints the first 2 pages and the prints a page with message memory allocation failure (514,10,72). If i try to print from the middle for example pagew from 20 to 30 it prints the first 2 pages and the same error on third page.
    I tried from other pdf files and it prints ok, from word files prints ok.
    I printed the problematic file to an Kyocera FS 2540 with no problem.
    Can anybody explain what happens?
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: TA 5500i
    Are Vector or Raster graphics used inside the PDF.
    Open the PDF file with a PDF editor program and flatten the vector graphics down to raster images.
    Alternative:
    Open the PDF file with any PDF reader an the click print to file and save the print file as a *.XPS meta file to remove invalid PDF corruption, page breaks, line spacing etc...
    HTH
    • copier tech
      • 8142
      Re: TA 5500i
      Update your printer driver & firmware.
      • gregrcs
        • 22
        Re: TA 5500i
        Are you using the KX driver ?
