F247 Kyocera 3550IDN
  • rvptor
    • Aug 2018
    • 19
    Hi guys,
    I have a problem with Kyocera Ecosys M3550IDN. When I turn on machine, i get System Error F247, without posibility to enter Service Mode (10871087).
    I tried to upgrate Firmware, but that doesnt helped me. I tried to remove Fax System, but also, I get the same error code. If u have any idea what could be, I appreciated. Best regards.
  • copiertec
    • Jan 2016
    • 2184
    Re: F247 Kyocera 3550IDN
    Does this model have the optional HD-6 or HD-7 installed? If so, remove it/them and see if that resolves the issue.
      • 22927
      Disconnect the network cable, then reboot. Does it re-occur? If not, you might have corrupt or non-print data hitting the printers IP address. =^..^=
      • Tonerkiller
        • Oct 2012
        • 665
        I have seen this. The HD is Bad. Format the HD then you will get a HD code C0640
        • robscopyr
          • Mar 2009
          • 54
          Black cat is right, unplug the network, if the error goes away clear the print que and re-test. I have never seen it be the HDD problem personally, I work in a hospital and I see this error every week, usually its somebody printing from the internet and using a browser to print a PDF instead of using acrobat reader.
