Kyocera TASKalpha 306ci scan to yahoo email fails
  • SATech
    • Dec 2019
    • 6
    [Misc] Kyocera TASKalpha 306ci scan to yahoo email fails
    The machine has been set to scan to a gmail account and works fine. The customer wishes to use a yahoo account going forward. This fails. I have verified the username and password the SMTP settings. Network settings should be good for either email service. I used these settings:
    • Set SMTP Protocol to On
    • Set SMTP Port Number to 587
    • Set SMTP Server Name to smtp.mail.yahoo.com ​*also tried IP address
    • Set SMTP Server Timeout to 180
    • Set Authentication Protocol to On
      • Set Authentication as to Other
      • Set Login User Name to <email address>
      • Set Login Password to <above email address password>
    • Set SMTP Security to STARTTLS
    • Set Sender Address to the _same_ email address as used for the Login User Name
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: Kyocera TASKalpha 306ci scan to yahoo email fails
    What error code are you getting ? That's always the best place to start.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • SATech
      • Dec 2019
      • 6
      Re: Kyocera TASKalfa 306ci scan to yahoo email fails
      SMH
      Error is 1102.
      • CWP
        • Jun 2013
        • 168
        SATech, I believe yahoo SMTP port should be 465 with security set to SSL/TLS. I also think that you have to have the actual, correct account name (i.e. XXX@yahoo.com) entered for the "Sender address".
        • SATech
          • Dec 2019
          • 6
          CWP, Thanks for the reply. I did try Ports 25,465 and 587 as well as the username XXX@yahoo.com and password that i used to log into the account on the web. SSL/TLS was the first security settings I tried.
          • tmaged
            • Oct 2008
            • 1890
            1102 is a username/password authentication error. I know you said you used that account to log into through a browser, which was going to be my suggestion. I'd try setting up a new account just to test.
            Hope that helps !
            -Tony
            www.dtios.com
            • SATech
              • Dec 2019
              • 6
              I did use the info from the browser I even copied and pasted. I will give a different yahoo account a shot. Thanks tmaged
              • brewindrew
                • Nov 2019
                • 1
                Yahoo Mail no longer has a security setting to Allow Less Secure Apps. Go to Account Name, Account Info, Account Security and Generate App Password. That will be the one to use in the MFP for authentication. For how long???
                Generate third-party app passwords |
                Yahoo Help
                - SLN15241
                • SATech
                  • Dec 2019
                  • 6
                  WoW great info Thank you!! I had someone tell me the same thing today!?!
                  • GeneOR95
                    • Feb 2018
                    • 161
                    From Yahoo's POP access settings and instructions for Yahoo Mail page at
                    POP access settings and instructions for Yahoo Mail |
                    Yahoo Help
                    - SLN4724
                    POP settings for Yahoo Mail
                    Incoming Mail (POP) Server
                    • Server - pop.mail.yahoo.com
                    • Port - 995
                    • Requires SSL - Yes
                    Outgoing Mail (SMTP) Server
                    • Server - smtp.mail.yahoo.com
                    • Port - 465 or 587
                    • Requires TLS - Yes (if available)
                    • Requires authentication - Yes
                    Your login info
                    • Email address - Your full email address (name@domain.com.)
                    • Password - Your account's password.
                    • SATech
                      • Dec 2019
                      • 6
                      Thanks for the info Gene.
                      • GeneOR95
                        • Feb 2018
                        • 161
                        Hope it is helpful.
