3501i Error C-3300
  • copydocinc
    • Mar 2015
    • 263
    3501i Error C-3300
    Hello friends,
    I have been trying to repair my customers Kyocera Taskalpha 3501i that started out getting a C-3300 error code intermittently, as they
    would turn the machine off and on and get it to work again. They tell me this went on for about a month, approx. every 3 or 4 days between working and getting the error code. Then it wouldn't clear the code and wouldn't work anymore, so they called me in.
    I have done everything listed in the service manual on this code. I Replaced the following: LED lamp PWB, CCD PWB, ISC PWB, Main PWB (actually sent the Main PWB to Hytec for repair), all wires in the scanner area, including the lamp ribbon wire, the 2 wires that come down and connect to the main pwb. The lamp lights up during warm up and through simulation 61. I re-installed the newest firmware 7
    So, I'm looking for someone who has had the same problem and fixed it or if you have any good ideas.
    Please help if you can.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1876
    Re: 3501i Error C-3300
    Two firmware updates addressed the code in E197 & H121. That's all that came up on Astea.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      What about the scanner motor, does it move at all?
      My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        Only to spin.. most scanner motors don't have a 'tensioner' adjustment.. if belt is too slack .. replace it.
        • copydocinc
          • Mar 2015
          • 263
          Yes, the scanner motor turns. I did move the 1st mirror arm over to re[lace the lamp board and the lamp ribbon wire, then as it tried to warm up it moved left and lamp turned on for it's normal short cycle. Then 3 or seconds later--C-3300.
          • Dan J
            • Oct 2011
            • 25
            It was the CCD PCB (u) that fixed our customers.
