M3540idn part identification (tray size sensor)
  • copiertec
    • Jan 2016
    • 2211
    This is a tray 1 size sensor attached to the M3540idn, I looked in the parts manual but can not find this part #. Anyone have the part #? Thank you.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: M3540idn part identification (tray size sensor)
    [ATTACH=CONFIG]45655[/ATTACH]
    I think this is what you need item 2
    Regards Mark
    • copiertec
      • Jan 2016
      • 2211
      Just looked at a 3640 we have in parts, the switches are not the same as the 3640 is on the left side, this one is on the right side.
      • lees
        • Apr 2011
        • 95
        Here is a part number we have for the FS2100 which is the printer this MFP is based on. It should be the same even though it is a strange number.
        5FSP03090001+01 cassette size switch
        • copiertec
          • Jan 2016
          • 2211
          That is the same # as the 3640mfp switch, I removed one from a parts machine, they are not the same as the M3540idn switch, its totally different. I have re read the m3540idn parts manual several times and it is not listed (edition 5).
          • JR2ALTA
            • Feb 2010
            • 2033
            My FS2100/4200 manual has 7SP03072001+H01 as the likely canidate.
            • JR2ALTA
              • Feb 2010
              • 2033
              I dunno, maybe that's just the front door switch. Your best bet is to get a hold of the Dallas Parts Department.
              • copiertec
                • Jan 2016
                • 2211
                That's it, I believe, looks the same in the pictures I searched, it says it work for a TA 3500i as well, we have a few parts ones I can search. Thank you, JR2ALTA.
                • KYO_OEM
                  • Aug 2011
                  • 727
                  You also can use partslist from PF-320/ Paper feed section 1/Item #17
