ECOSYS M2040dn - knocking noise
  • kuby
    • Oct 2007
    • 1409
    Have a M2040dn making a knocking noise coming from the toner/developer/drum section I think. Any one run into this before? Do not know if it is the paper feed which I don't think it is or a bad developer unit or drum unit. Both turn fairly easy.
  • craigster
    • Apr 2016
    • 201
    Re: ECOSYS M2040dn - knocking noise
    I had one of those making a knocking noise and it turned out to be a fuser which they changed to correct it and also jamming once in a while
    • kuby
      • Oct 2007
      • 1409
      Thanks will look at that tomorrow. Not jamming just a popping noise.
      • JR2ALTA
        • Feb 2010
        • 2033
        It's the fuser. The noise echoes throughout the machine. I thought it was paper lift, then drum/dev. First time I saw it I turned the fuser by hand and it seeemed fine and after re-installing it went away for a couple months. Came back and I changed the fuser. Have seen this issue a couple more times since then on other machines.
        Like the above post says the fuser has a couple bulletins...will also cause non-stop 42xx jams.
        • kuby
          • Oct 2007
          • 1409
          Thanks for the help. What I did was remove the fuser drive assy and took the cover off and two gears and there is a tension spring under them. I stretched the spring and put it back together and installed the fuser drive and fuser and tested. No popping. Figured it was worth a shot. So I guessing the spring tension had weakened and let the gears slip a bit.
          • Calliem
            • Jul 2015
            • 14
            replace toner cartridge,might help have had a couple of those where it sounds like machine is stripping every gear it has but was only toner cartridge problem
            • kuby
              • Oct 2007
              • 1409
              first Thing I tried was replacing toner cartridge.
              • KYO_OEM
                • Aug 2011
                • 721
                very often broken gears in fuser drive
