Kyocera 3051ci account ID
  • bayshoreoe
    • Jun 2015
    • 44
    Picked this unit up wholesale and it comes up with "enter account ID" screen. Can't seem to get into service mode either. Is there any way to get around this or get into service mode to do a HDD format or machine initialization?
    TIA
    Brian
    • 23010
    Re: Kyocera 3051ci account ID
    If you know the IP address you can do a Prescribe command engine reset.
    • kyotechnz
      • Mar 2019
      • 148
      You need to turn off Job Accounting.
      You can do this through the System Menu.
      There you will see User Login\Job Accounting, use the 3000 for the username and password.
      You should find in there the option to turn Job Accounting off.
