FS-C8020 F24C fault > Firmware update source?
  • Spooltasker
    • Sep 2019
    • 7
    Hi all,
    I have a FS-C8020 that has started giving F24C faults, requesting a power cycle, they only appear to happen when attempting to login as admin to the command center, which also gets stuck and does not log in.
    First thing I wanted to try was a firmware update, I know there have been updates, but it seems Kyocera keep them under lock and key, as such I was wondering if anyone could help me with finding current FS-C8020MFP Firmware?
    The machine in question has firmware 2KZ_2F00.001.504 dated 2011.02.08, others I work with are dated as new as 2015.05.13, so there have been changes.
    Thanks for reading.
  • copier tech
    • 8142
    Re: FS-C8020 F24C fault > Firmware update source?
    Originally posted by Spooltasker
    Hi all,
    Thanks for reading.
    [ATTACH=CONFIG]46026[/ATTACH]
    This error can also be caused by a corrupt print job.
    But firmware is usually required to resolve the issue, drop us an email if you need it.
    Firmware Update - Printer & Copier Firmware
    • JR2ALTA
      • Feb 2010
      • 2033
      Delete the print job from the source computer or server. Avoid printing from internet.
      Or
      Some f-codes are corrupt fax data. Get into simulations and clear fax memory.
      • Spooltasker
        • Sep 2019
        • 7
        Thanks, will do.
        Or
        Thanks, I'll do as you mentioned and see if I can log into command center.
        • rapo_tech
          • Feb 2019
          • 114
          Problably same problem as here - Kyocera can't access command center printer web page (fix)
          I tried frimware update on 8520.. nothing changed...
          • kuby
            • Oct 2007
            • 1400
            Did you do a full update or use the Turbo pack. If you are experiencing problems always use the Full Firmware package and not the Turbo pack. Just to let you know.
            • rapo_tech
              • Feb 2019
              • 114
              Yup, did the full update...
              • autopilot
                • May 2011
                • 68
                I have come across this on a few devices recently - different older models Utax 206ci (same model as the FS-C8020 I Think) and M2535DN both on current FW.
                I'm not sure if this has been caused by recent Win 10 updates or Chrome itself but only workaround I have found is to use internet exporer. I haven't tried other browers but Chrome causes F24C after logging in as Admin and IE doesn't. 3 Machines in total now.
                  I would give firefox a go.. hardly any issues that I've had and I know other senior tech here use it
