Heading out the door so this will be fast and probably incomplete, I'll pick this up this afternoon...
TA-307 159k count, C7620 error every 100 to 200 prints. I would clean the registration lenses and the code goes away. I run a calibration U464? the check the U904 for an error, then repeat the cleaning if needed. This works every time. If I just run the calibration U464 without cleaning, the U904 count goes up. So it works...
Had streaking issue at 149k and replaced DK-(K),TR, and TB. I had a MK available so I was able to swap all three parts with new. Swapped each as and individual and then ran prints, so I determined that all three needed replacement.
Talked to the IT guy and he said that the previous machine from a different dealer had issues with the transfer belt as well.
Ours is on KFS and firmware is up to date.
Every patient gets a normal letter, wrist labels and full page labels. My guess is that labels are gumming up these parts. They are Laserband brand and they don't feel "gooey" on the print side and all of the part are below the fuser (so the labels are room temp while going through the transfer).
Any thoughts?
Thanks,
Any thoughts?
Thanks,
