Jamming duplex Kyocera ecosys 2035
  • roger19
    • Jul 2025
    [Jamming] Jamming duplex Kyocera ecosys 2035
    Hello for every body, I have a problem with Kyocera ecosys 2035, the sheet of paper stops in duplex area, I'm new in this brand, for your help thanks
  • Santander
    • May 2009
    • 768
    Re: Jamming duplex Kyocera ecosys 2035
    Do you have a jam code you could share with us? When it jams is by the fuser? When duplexing have you observed if the paper has problems being reversed in the paper conveying section. Most likely you have a bad solenoid in the paper conveying unit and the machine cannot pull the paper back for the second side.
      • 30091
      look for a switch pop out of its mount
      just snap it back into place.
        • 23003
        First thing to do is to print off the error log, to see what the jam code is. =^..^=
