TA 4551ci etc... Feed tire "walking off" Feed tire holder...
  • Doug James
    • Jan 2012
    • 935
    [Jamming] TA 4551ci etc... Feed tire "walking off" Feed tire holder...
    Hello, Lately I have had a few feed tires (Mainly the one above the sep roller or the sep roller itself) Am I doing something wrong or do I need to check something before I install it. I thought about putting a little super glue on the end. It usually walks off over the clip where it secures itself to the shaft... Thanks so much !!!
    • 23010
    Re: TA 4551ci etc... Feed tire "walking off" Feed tire holder...
    I have seen the rubber walk off of the hub, and consequently wear bell shaped. And if I used the Kyocera rollers as replacements I might add a spot of superglue to keep it on the hub, but I'm using (2) A00J 5636 00, and (1) A5C1 5622 00, Konica Minolta rollers.
    I press them off of the hubs, then back onto the Kyocera hubs. And they don't walk off. And they last considerably better than the 150K Kyocera claims for them.
    It's up to you. =^..^=
    • Doug James
      • Jan 2012
      • 935
      That's GREAT !!! I so appreciate your help !!!
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        I've never had original feed rollers come of the roller hub. I would only use oem parts and not cheap tyres only from China {buy cheap buy twice}
        Regards Mark
        • Calliem
          • Jul 2015
          • 14
          ill second that one,been using minolta rolly polys aswell for a long time,they work great,the red ones though,the green ones not so well
            • 23010
            Agree on the greens. 50% of life at best.
            This might be pertinent:
            https://www.copytechnet.com/forums/k...tml#post526551
            • Tonerkiller
              • Oct 2012
              • 669
              OEM all the way. Those katan rollers are junk
