Repeated black dots, Kyocera TASKalfa 3510i
  • kykinvc
    • Jul 2020
    • 2
    Hi, since like a year ago the printer (Kyocera TASKalfa 3510i) started printing a line of black dots. Currently, there are 5 lines of dots. The distance between a dot in the same line is 1.5 inches (38.5 mm). I attached a paper with the other distances between dots. Could someone please tell me what is the source of the dots? Thank you.
  • copiertec
    • Jan 2016
    • 2172
    Re: Repeated black dots, Kyocera TASKalfa 3510i
    1) did you refer to the repetitive mark gauge in the service manual?
    2) what direction are you running the paper through the paper tray?
    3) How many clicks on maintenance items? vs total clicks?
    • Ropariva
      • 591
      Your gonna need a main charge roller. 38mm diameter
      • tonerleak
        • Mar 2012
        • 67
        Yep, that's definitely a charge roller, don't even bother to try cleaning it.
        • kykinvc
          • Jul 2020
          • 2
          Thank you for your responses.
