Error code: 0150
  • AlexRust
    • Apr 2014
    • 41
    Error code: 0150
    Please somebody email me link to download latest firmware for Kyocera FS-4100DN.
    Thank you
  • AlexRust
    • Apr 2014
    • 41
    Re: Error code: 0150
    There are some additional strange behavior - it will print without toner cartridge; when I turn printer on without toner it show "Non genuine toner installed" message, "Stop" + "OK" will clear this message and display show "ready to print". If I turn on printer with toner installed - I get 0150 error message.
    Can anybody please explain why printer doing this and how to fixed it. I did factory reset, remove and reinstall developer in toner multiple times.
      • 8164
      Thank you
      Updating the firmware may resolve this issue but there is no mention of this is the service manual.
      • Description:Backup memory read/write error (engine PWB)
        Detecting engine PWB EEPROM communication error.
      • Causes:Improper installation engine PWB EEPROM. Defective engine PWB. Device damage of EEPROM.
      • Remedy:Improper installation engine PWB EEPROM. Check the installation of the EEPROM and remedy if necessary.
        Defective engine PWB. Replace the engine PWB and check for correct operation.
        Device damage of EEPROM. Contact the Service Administrative Division.
      โ€‹
      • lees
        • Apr 2011
        • 95
        Using generic toner will sometimes cause this issue. Also if the chip on an OEM cartridge is bad, it can cause the issue. Install a new OEM toner cartridge and the issue will probably go away. We have seen this many times.
        • AlexRust
          • Apr 2014
          • 41
          Thank you. New toner will arrive on Fri. Will report back. Any chance to get firmware?
          Here is what installed on my unit:
          System Firmware:
          2LV_3F00.012.003
          Engine Firmware:
          2LV_1000.010.001
          • AlexRust
            • Apr 2014
            • 41
            All good. New toner cartridge solved all problems. Thank you all.
              • 8164
              โ€‹
