Kyocera TASKalfa 356ci, dim line in color print out
  • captaindan
    • Sep 2020
    • 3
    Hi Everyone,
    Had this printer for a few years, this morning i printed out a picture and it has a line through the middle that is obviously missing some color. Not sure if this is something that needs to be manually cleaned or i can run some sort of maintenance. I included a picture of the issue. All help appreciated, thanks again.
    Re: Kyocera TASKalfa 356ci, dim line in color print out
    Originally posted by captaindan
    Hi Everyone,
    [ATTACH=CONFIG]46745[/ATTACH]
    how many pages on the drums/ITB?
    did you get ur users manual out and perform all cleaning procedures?
    what have you done?
      • 16490
      Hi Everyone,
      You need to clean the laser. I'll see if I can find the instructions.
      Edit: I don't have the manual for this model but most TaskAlfas you can clean it by going to the System Menu and then select "Clean Laser". But not sure about this model.
      • captaindan
        • Sep 2020
        • 3
        It was the one test i didn't run and it seemed it was the laser, thanks for the help appreciate it
        • captaindan
          • Sep 2020
          • 3
          it was the laser cleaning, somehow that was the one test i missed on my checklist. Thanks for the help everyone
            • 23010
            Were I to make a guess I'd say it was the cyan slit glass that was dirty. =^..^=
