M3655idn print/copy hesitation issue
  • progoffice
    • Nov 2008
    • 337
    We have a M3655idn that is exhibiting a strange issue. On both copying and printing, the MFP hesitates after ever 4-5 pages before printing the next 4-5 pages out and the cycle repeats until the job is complete. As a test, I made some copies in silent mode, and the same cycle continued, only slower due to the silent mode setting. The same happens when duplexing. I've updated firmware, performed U021 and no change. My only guess is that the onboard memory on the main board is faulty. Since this is also happening when copying, I think it's safe to eliminate any print driver troubleshooting or settings related to printing. Any ideas?
  • kuby
    • Oct 2007
    • 1414
    Re: M3655idn print/copy hesitation issue
    Toner levels?
    • progoffice
      • Nov 2008
      • 337
      I forgot to mention that the toner level is at 100%. We've considered this as a possible cause but not in this case. Thanks for the reply.
      • kuby
        • Oct 2007
        • 1414
        Do a firmware reload. A full version and not the update (turbo).
        • progoffice
          • Nov 2008
          • 337
          I did that as well without any change. I really think it's the main board, but we'll have to order one and replace it to find out. I can report back once this has been done, but still open to suggestions.
          • Ropariva
            • 703
            • progoffice
              • Nov 2008
              • 337
              I was thinking it might be fuser. Would it hesitated just getting started or throughout the entire job?
              • Ropariva
                • 703
                Just starting. Also seen similar things on other brands with faulty cavity thermistors
                • progoffice
                  • Nov 2008
                  • 337
                  Actually the first tech on this said he's already replaced the fuser, so I don't think that's what it is in our case. But I guess since it's still doing it, it could be that the fuser can't keep the temp up and pauses until it reaches the right temp to start running again. That would maybe point to the board that controls the fuser temp.
                  • toddanderson
                    • Dec 2005
                    • 238
                    Primary feed is slipping, worn tires or missing spring in primary feed.
                    • lees
                      • Apr 2011
                      • 95
                      Make sure the spring is on the feed holder assembly. We have seen this spring missing or out of place and cause this issue. The machine tries to pick up paper but sometimes it has to try several times before it picks it up. It usually will not show a jam, just slow printing.
                      • craigster
                        • Apr 2016
                        • 201
                        Since you have done sim 21 I would try doing the same job out of the bypass tray and see if it exhibits the same issue. If it works fine I would check the spring being displaced on the feed assy for the main tray. I had the same issue on a M6525cidn.
                        • progoffice
                          • Nov 2008
                          • 337
                          It does the same thing through the bypass tray and the spring is in its correct position for the main tray.
                          • spw
                            • Mar 2015
                            • 62
                            Whats the coverage on the page? If heavy it could be adding toner like normal. But you might look into the Dev unit to start.
                            • tsbservice
                              Field tech
                              • 8064
                              What did you mean by hesitation?
                              I've seen similar waiting/pause before print on other brands and it was either:
                              a) adding toner
                              b) waiting for fuser temp to stabilize
                              c) when HDD started to fail in which case format of HDD temporary took care of the issue
