Kyocera TA-3551ci showing memory full when scanning
    • 30476
    #16
    Re: Kyocera TA-3551ci showing memory full when scanning
    This is where my lack of knowledge holds me back. My friend who is the computer guru and IT person at the account told me that it uses more memory after I suggested using high compression pdf. I'm gonna have to go over to the account and try it myself.
    Again, thanks for the help.
    Nope Your IT friend doesn't know copiers work good luck
    Compression is done on the hhd not using the ram memory that's why small machines with no hhd can't do it and that feature is unavailable.
    PS AUTO COLOR creates a file 4 times larger either in color or b|w docs
    even a black doc file is huge
    Also set it for text
    • tech07
      • Aug 2008
      • 410
      #17
      I've been able to resole a couple by switching to KX driver.
        • 16472
        #18
        even a black doc is huge
        You've got me convinced. Now I will convince him. Thanks.
          • 30476
          #19
          It's a scanning problem not a printing issue
            • 16472
            #20
            Dude, how can you be so smart about this stuff and not know a damn thing about politics?
            I kid. I kid. You've been very helpful.
              • 30476
              #21
              Been working on Kyocera Mita for about 30 years
              Factory trained, been doing the IT stuff since they came out with a print system.
              Do a 906 reset when you get there
                • 16472
                #22
                Remind me to be nicer to you.
                  • 30476
                  #23
                  Standard defaults for scanning
                  usually set
                  150dpi
                  black
                  text
                    • 16472
                    #24
                    usually set
                    150dpi
                    black
                    text
                    Yeah, but they do heavy scanning and some of their medical charts are in color. I can't default to B&W.
                    By the way, what is executing sim. 906 gonna do for me? Just curious. I'm gonna do it.
                      • 30476
                      #25
                      906 is standard reset on all kyocera machines
                      It reset any faults detected by the machine ie paper tray, sorter , adf
                      You may also want to check to see if new firmware is available
                      Than set Auto Color you can turn on high compression only if needed it will delay the scans for a little bit it has to compress them than send
                      150 dpi and text
                        • 16472
                        #26
                        Than set Auto Color high compression
                        150 dpi and text
                        Yeah, I know what 906 does I was just curious what it would do for a memory full message. That's not really an error code. Nonetheless, I will do it.
                        I already installed the latest firmware.
                        Will change to auto color, high compression and 150dpi.
                        I owe you. Thanks again.
                          • 30476
                          #27
                          don't forget to change to text text/photo using more file size
                            • 16472
                            #28
                            I'm playing around with the settings on a machine at the shop and I don't see where I can default to high compression scans. At least not thru the command center?
                              • 30476
                              #29
                              Don't know if it's in the command center in past I've always set it on panel. but very very rare setting out of the thousands of installs I've done
                                • 16472
                                #30
                                Just to follow up, I changed all the settings to your recommendation and then scanned some color pages and they look acceptable to me. Was worried that the low resolution would look like crap but it's good.
