TA 4551 DP 790 Not communicating with Copier
  • Doug James
    • Jan 2012
    • 935
    [Misc] TA 4551 DP 790 Not communicating with Copier
    Hello, When I put paper in the ADF (DP 771) the Green light comes on that says it has paper but won't feed it when I hit the start key. It also won't show the 2 sided function under the "duplex" as in... 2 to 2, 2 to 1 etc.First I did a U906 No luck...Then I changed the entire feeder also the board directly under the feeder in the rear of the copier. (Not sure the name). I also installed the latest firmware. I feel like it's something simple and I went overboard. Thanks so much for any help !!!!
    • 16486
    Re: TA 4551 DP 790 Not communicating with Copier
    There's a DP-770 and DP-772 for this model. There's no DP-790. There is a DF-790 but that's a 4000-sheet finisher. Which DP do you have, 770 or 772?
    • Doug James
      • Jan 2012
      • 935
      It's a DP 771... The Dyslexia is acting up again....
        • 16486
        Execute U203 by placing paper in the DP and see if it feeds paper. That's where I would start.
          • 16486
          According to the specs that I'm looking at, you can only use a DP-700 or DP-772. Now, I only pulled up the brochure but I'd double check if I were you.
          • Doug James
            • Jan 2012
            • 935
            That's probably it, I don't have a U203 option that comes up in service mode either... That sure sounds like it. I will let you know THANKS SO MUCH !!!
            • Doug James
              • Jan 2012
              • 935
              The DP 770 worked just fine... You were right... Thanks so much !!!
