M2540 noise after fuser replacement
  • allstar59
    • Oct 2012
    • 64
    When I have replaced the fuser on a few of these machines they sound like an old washing machine, they work fine but are noisy ...the noise sounds like it's coming from the fuser\duplex area but I can't pinpoint it. This has happened on several machines so I can't blame it on one defective fuser. they were nice and quiet before the fuser swap. Anyone else noticed this? Thanks
  • lees
    • Apr 2011
    • 95
    Re: M2540 noise after fuser replacement
    We had one of these that we had to replace the fuser drive unit. Instead of the fuser making the noise, it was in the drive unit. To my knowledge the problem never came back.
    • Santander
      • May 2009
      • 768
      There is a TB out that pin points the noise to either the rachet gear or the main drive gear in the fuser drive assembly. We replace the fuser drive assembly and then rebuild it in the shop replacing both the rachet gear and the main drive gear. Replacing the drive assembly takes two minutes.
      • allstar59
        • Oct 2012
        • 64
        Thanks for the quick reply! I'll get a few drive assemblies and gears on order Monday. I I searched the portal for bulletins or QA but I must have missed it. I called tech support about it and he told me to put it in quiet mode (joking I hope) but he didn't see it ether.
        Thanks for your help, Jim
