DP-770 (Document Processer) No Feed
    • 16473
    Thought I'd share this.
    I had a DP-770 that wasn't feeding. The pickup roller wouldn't pull the paper far enough in for the primary feed roller to feed the paper thru. The pickup roller has a one-way bearing so I thought it would be a simple fix by replacing the pickup roller. After replacing there was no change.
    So, I enter sim. 203 and run the doc. feeder without paper. I notice that the pickup roller would turn sometimes but other times wouldn't move at all. The feed motor worked fine. I had never taken the gear pack off one of these but I figured there must be a gear with a one-way bearing in the gear pack that was slipping. Sure enough i take the gear pack off and replaced gear with one-way bearing and that fixed the problem. Anyone ever run into this?
  • taskalfaman
    • Nov 2009
    • 137
    Re: DP-770 (Document Processer) No Feed
    [ATTACH=CONFIG]47233[/ATTACH]
    hi,
    most likely is the black holder defective, the black stopper lever is probably gone.
    have Fun
    • ntbann
      • Jan 2012
      • 631
      taskalfaman he was hiving us a pointer not asking for help. If you would have read his post he said what the issue was!
        • 23010
        I've dripped oil into this one-way for a quick fix. I've never had to actually remove it. Nice that you confirmed it for me though.
        The misfeed is J9000, and the one-way gear Z27R is 303LL31440.
          • 16473
          Removing and re-installing this particular gear pack wasn't that bad. Of course this was my first time and that's always the most difficult. I did it a 2nd time and didn't make any of the same mistakes the first go around.
          I'm always hesitant when I dig into a gear pack because back in the day I took one apart on a Sharp and springs and shit started flying thru the air. This was a cake walk compared to that.
