Kyocera 420/520 series doc feeders plate not rising.
  • Tom
    • 342
    Has anyone seen this problem before, only on these models? I've never seen it before on the 3050/4050/5050 series machines, but the upgrade of it (420/520) seems to have a problem with the paper lift plate on the DF. Weird thing is if you push down on the back corner the problem seems to go away until the next time it gets raised, then the problem occurs again. This is the 3rd time I've seen this on this model, but now I don't have any to swap out so I guess I need to figure out what's going on.
    Re: Kyocera 420/520 series doc feeders plate not rising.
    On the 4050 and other similar models, there's a cam that raises and lowers the lift tray. Sound like something is binding or the lift motor isn't working properly.
      • 22929
      Does it store a C-9050? =^..^=
        The man knows his stuff.
        C9050:
        Causes: Loose connection of the DP lift motor connector. Malfunction of the DP lift motor. Loose connection of the tray lower limit switch connector. Malfunction of the tray lower limit switch.
        • Tom
          • 342
          No code, probably cause there's nothing wrong with the motor. Like I said, if you push down on the back rear corner hard it starts working again until the next time it gets raised, then it stops working. That eliminates motor and wiring. I'd say bent frame or something but it's happened on multiple feeders of that model so I was hoping someone else had seen it. I've got one hooked up in the shop now so I'm going to figure it out this coming week and let you know what it was.
          • Tom
            • 342
            Oh, and as an afterthought for anyone that doesn't know, those green sep rollers that fit both the older 3050 4050 5050 machines and the newer yellow sep rollers you see on newer machines are interchangeable if you need to. The yellow ones work better as they have more texture but they are also more expensive, however I did find them on ebay at a fraction of the price. They come from china so give it a month, but so far they've worked well.
              • 22929
              These couple database entries for the FalconIII (CS-5050) came to mind while reading your thread. We had hundreds of the FalconIII and very few of the 420/520. The Saturn also had the DP-750/760, but I have seen what you describe:
              DP-700 is unresponsive. "C9050" displayed at initialization. Red error LED. DP original tray lifts (3) times before presenting the code, then the code disappears. A large paper clip, paper, or staple is lying on top of DPLLLSW (DP lift lower limit switch) preventing the flag on the tray from dropping through the sensor. Remove the original tray to see, then remove the paper clip from the DP lift lower limit switch.
              Lift plate does not lower after original set is complete. No jam or error is recorded. Paper scrap blocks DP lift lower limit switch. Clean DPLLLSW: remove front and rear DP covers, DP drive relay PWB, front and rear tray posts, raise lift tray to clean sensor.
              "Adjusting Scanner" message, whenever originals are placed in the DP-700 document processor and Start pressed. Message does not clear. Top cover of document processor has been forceably opened, damaging the rear hook and interlock switch holder. Replace rear hook (303JX07180) and interlock switch holder (303JX02240).
                The database is undefeated.
                  • 22929
                  We shall see. =^..^=
                  • kjg
                    • Mar 2009
                    • 111
                    I have seen exactly what you are describing on several 420/520 DP760's.
                    My only suggestion is to replace the top door as an assembly. It has something to do with the top cover. It acts as if the upper limit sensor is actuated when it should not be. I have just placed my hand on the center of the top of the ADF and had it work just by may hand weight being there. The upper limit flag is not broken (as I have seen that too several times). I wish I had more to share, but replacement of the top cover has been my fix for that problem.
                    The feed shaft runs only half way through on that model as opposed to the others having a full shaft. Perhaps over time the stresses on the drive causes the feed to stall momentarily and trigger the Upper Limit Sensor when it should not.
                    • Tom
                      • 342
                      KJG is absolutely correct about what is happening. I had some time today to mess with it, here's the symptom. Cam does not turn and allow plate to rise. If you put pressure on top cover assy that contains feed belt it will then raise and continue to raise until the next time you open and close the top cover and then problem repeats. I tried opening the cover while keeping the interlock closed and I can see the cam move a bit but it stops and doesn't raise the plate. I think this feeder has another way of knowing the cover is open and when it thinks it is it won't rotate the cam to allow the plate to rise all the way. Now get this, I took the gear off that drives the feed belt/PU roller and closed it back up and the plate rises every time. Of course, without the gear it can't feed, but this proves to me it's not a motor problem. Put the gear back on and it doesn't rise unless you press down on top cover and then it will engage and keep working until opened again. Argh. I checked and the gears are engaging and turning the feed belt/PU roller. KJG says replacing the top cover assy fixes the problem, but for the life of me I can't figure out why it would or what's causing it to act so weird.
                      • kjg
                        • Mar 2009
                        • 111
                        I sure hope you can see something I don't.
                        I would like to know what truly causes it.
                        I have a hunch the cover warps up in the center over time and causes the difficulty.
                        I have had customers who were billable and didn't want to pay for the price of a new cover just park a stapler on the top cover over the feed head and they never had the problem come back. Yeah, I know its a very bad place for a stapler. But it works.
                        Remember, the feed shaft is only a half shaft and not a full shaft. I think that plays into the problem quite a bit over the course of time.
                        Originally I had thought it had something to do with the sensor on the front of the white plate (reading guide) on the bottom of the ADF but could never link that to the symptoms.
                        Please post if you find out anything different.
                        KJG
