SU KYOCERA ECOSYS M2735dw
  • CIRO
    • Apr 2020
    • 33
    Buonasera,
    su kyocera m2735dw con circa 50.000 copie inceppa il foglio tra forno / uscita copia con macchie scure cortesemente qualcuno puo' aiutarmi a capire visto che anche su stampante kyocera
    ECOSYS P2040dn con circa 50.000 copie ho avuto lo stesso problema.
    Grazie
    Re: SU KYOCERA ECOSYS M2735dw
    Originally posted by CIRO
    Buonasera,
    Grazie
    IN ENGLISH Please
    • kyotechnz
      • Mar 2019
      • 131
      Buonasera,
      Grazie
      on kyocera m2735dw with about 50,000 copies jams the sheet between fuser / copy outlet with dark spots kindly someone can help me to understand since also on kyocera printer
      ECOSYS P2040dn with about 50,000 copies I had the same problem.
      (According to Google Translate)
        Jam codes?
        clean sensors?
        oem genuine KM tone/drums?
        life on drum/toner?
        what have you attempted to solve the issue?
        do you have the manual?
        Phil B. ' The Dentist '
        • Santander
          • May 2009
          • 768
          Buonasera,
          Grazie
          Most likely you have a bad fuser assembly. The dark areas are caused by the fuser heat film having trouble rotating which then could cause the paper to arrive at the exit sensor late. Change the fuser.
            • 22930
            • CIRO
              • Apr 2020
              • 33
