Copystar CS 3550ci Buzzing (Grinding) Right side Transport Assy Dood
  • Doug James
    • Jan 2012
    • 935
    [Misc] Copystar CS 3550ci Buzzing (Grinding) Right side Transport Assy Dood
    What is the part I need to fix this ? I used to just change the whole door out to fix this but I don't currently have any.... Thanks so much for your help !!!
  • mita
    • Sep 2010
    • 87
    Re: Copystar CS 3550ci Buzzing (Grinding) Right side Transport Assy Dood
    It is usually 302K924782 the plastic housing cracks and the worm gears pop
    • Doug James
      • Jan 2012
      • 935
      Thanks so much. Sure appreciate that !!!
        • 22930
        Are you getting a C2730 maybe? =^..^=
        • Doug James
          • Jan 2012
          • 935
          Not yet... Just started today
          • Doug James
            • Jan 2012
            • 935
            I have been looking at the Service manual... What is the best way to take the transport assy apart to get at it. Thanks !!
              • 22930
              You'll have to separate the 2nd transfer assembly from the outer door. You don't need to remove the door. But the springs are surprisingly beefy, that's what breaks the housing. IIRC you can slip the coil springs out before disassembly, then slip them back in after re-assembly. =^..^=
              • Doug James
                • Jan 2012
                • 935
                That's a HUGE help Thanks so much !!!
