M3550 not sending faxes, but will receive.
  • Scottb
    • Apr 2013
    • 306
    So I have ruled out the M3550, I took a 1135 known to work and a simulator box connected the two and both worked. Neither would send when connected to the customers phone line, so I know it must have something to do with their system.
    What's happening is the machine gets a dial tone, dials the number, and then it just rings and rings until it times out.
    Any help here would be appreciated, and will be sent on up the line...pun intended...
    Re: M3550 not sending faxes, but will receive.
    sounds like they are using a VOIP system.
      • 30293
      Change setting to PBX and try
      Also turn off v34 modem
      if need turn down send and receive to 9600 baud
        • 37532
        If the customer has recently changed their phone system, you may not be on an actual outside line. use the Off Hook button like you were going to manually dial a number and dial 9 only. If you get a reordered dial tone you are behind something.
        • copres
          • May 2011
          • 41
          So, did any of this rectify problem? What was solution? Has client with same problem now where old Minolta DI-351 was working okay but replaced with Kyocera FS-3140mfp and it will receive faxes but can't send. Thanks.
            sounds like they are running on a VOIP system
              • 23009
              U660 > Set Calls > Exchange > PSTN to PBx > OK
              • copres
                • May 2011
                • 41
                This made it work. Thanks a lot!
