Kyocera 3051ci prints blue haze on pages
  • stern.detmold.32756
    • Feb 2018
    • 25
    Hello everybody,
    i have a Kyocera 3051ci which prints a blue haze on every print which is coloured. If it is a black/white copy, this problem does not occure. Example is attatched. I already used the "Drum cleaning" program several times, it didnt effect the problem.
    Thanking you in advance
  • Ropariva
    • 657
    Re: Kyocera 3051ci prints blue haze on pages
    Originally posted by stern.detmold.32756
    Hello everybody,
    Hi,
    Have you tried calibration followed by the Tone Curve adjustment ?
    • rapo_tech
      • Feb 2019
      • 114
      Whats the total counter? OEM toners and parts?
      Try swapping blue drum with other color.
      Probably worn out drum surface...
      -edit- seems to me that repetitive defect indicates dirty/worn out charge roller. anyway swapping the drum confirms that. And new drum comes with new charge roll
      • Santander
        • May 2009
        • 768
        Hello everybody,
        If the example you provided is print on LEF it could be a drum problem. But I would not rule out that the Cyan HV is starting to short out if it was print SEF. Toner dusting could lead to the HV intermittently shorting creating a similar pattern.
          • Feb 2018
          • 25
          Thanks to everyone, i will verify if it was printed LEF or SEF, my guess was the drum actually. The total counter is 151065, coloured is 102343. I will let you know what i did and what fixed the problem
            • Feb 2018
            • 25
            Hi everyone, the customer called me today and the problem disappeared magically
            Thanks everyone for help
              • 16330
              That's always scary because it usually magically reappears at some point.
