TA-3551 Time for maintenance Tray 1
    • 16416
    Time for maintenance at Tray 1.
    This message is at the bottom of the screen. I replaced all the feed tires at Tray 1 and cleared the counter @ U901. This didn't get rid of the message. What am I missing?
  • Necrocannibal
    • May 2008
    • 212
    Re: TA-3551 Time for maintenance Tray 1
    251 is the simulation for maintenance counts.
    Sent from my SM-N986U using Tapatalk
      • 16416
      Thank you. That's what I was thinking. In the service manual for TA-3551, U251 doesn't show the option for setting the count for any of the trays but in the manual for the TA-3501 U251 does show the option for all of the trays.
      I don't have a 3551 here at the shop so I can't check it out. Thanks again.
      • Necrocannibal
        • May 2008
        • 212
        I don't have a 3551 here at the shop can I can't check it out. Thanks again.
        You're welcome, I haven't looked at that particular machine's 251 in a while but that is where you usually do it so I'm sure it's the same.
          • 16416
          Perhaps Kyocera made a mistake in the manual? I don't know but I can't find it anywhere else. See images below for U251 for both 3551 & 3501.
          • Necrocannibal
            • May 2008
            • 212
            I guess it's possible, it wouldn't be the first time. 251 is always where I've gone to reset those, I can look at our machine at work tomorrow morning just to see because I'm curious now.
              • 16416
              This is kind of a guess here, but in the 3551ci manual, it shows no way to reset the maintenance counter for Tray 1 using U251. Or any tray. However, under U250 the preset value is 150k for every tray. I suppose each time a feed assembly is rebuilt that you kick the preset value up by 150k. Thus, the "time for tray 1 maintenance" won't be displayed again for another 150k. I'll find out tomorrow.
              • Necrocannibal
                • May 2008
                • 212
                Well 250 is to set the cycle, not reset the count. I am really thinking it is just a screw up when printing the manual but I'll be at work in about an hour and will be able to look at one just just see for myself.
                • Necrocannibal
                  • May 2008
                  • 212
                  This is a pic of 251 on a 3551ci at our shop, like I said it must be a screw up when printing the manual.
                    • 16416
                    You are correct, they did make a mistake in the manual. I found another 3551ci manual and under U251 it shows all the cassettes. Thanks for your help.
                      • 16416
                      Thanks for your help. How long have you been working on Kyoceras and what's your opinion on them?
                      • Necrocannibal
                        • May 2008
                        • 212
                        I've been working on them for 30 years, back when they were Mita not Kyocera. My opinion is they are the easiest of the brands to work on, but I might be a little biased since I have so much experience on them. They are overall a great brand and don't really have a lot of issues, even though I'm having a weird black lime issue on a 7002i, other than that the 250, 300, 400 and 500 machines were total garbage but the rest are pretty good machines.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Hope this helps
                          Regards Mark
                            • 16416
                            Originally posted by mga
                            Hope this helps
                            You're always helpful, mga. Thank you.
                            Now I have a confession to make. There was no mistake in the 3551 service manual. It was an "operator" error and the operator was me.
                            I mislabeled the file for the 3551 service manual. I was actually looking at a 3550 manual. Sorry for wasting everyone's time.
                            • tsbservice
                              Field tech
                              • 8020
                              😆 Billy perhaps your head is starting to fill up with all new fancy network stuff you're learning atm virtually leaving no room for old copier stuff.
                              Also I have to admit you have balls dude
