TaskAlfa 3501i waste toner problem
  • copiray
    • Feb 2019
    • 29
    Hello, we have a 3501i in maintenance and it keeps warning that the waste toner bottle is full when it just has a little toner in the tank, the bottle has been changed for a new one, the tray has been changed, the waste toner collector , sensor and plastic that activates the sensor, any ideas?
  • eddie110171
    • May 2012
    • 133
    Re: TaskAlfa 3501i waste toner problem
    I would check the wire harness that connects the PARTS INNER UNIT which is the section you remove to access the drum and DV. I would suspect a bent pin or problem with the harness. Also check the waste toner bottle there are 2 parts to it the optical sensor and the diaphragm make sure both are intact and clean. I have inserted a brand new bottle and if toner gets on the window it shows full again because it blocks the optical sensor.
    • rapo_tech
      • Feb 2019
      • 114
      Update firmware to latest available.
      Run maint mode U155 waste toner calibration.
      -edit- Seems that this fix is for TAxxx2 machines...
      Anyway firmware update is a way to go.
      The problem could be dirty/stuck spring/sensor under the waste toner assembly.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Try new bottle make sure sensors are clean also check the drive gear that drives it I've had a couple of them break
        Regards Mark
          • 23009
          We've received a few badly manufactured waste bottles that the agitator was seized. I got one of them to rotate (it had popped out of the hole in the side of the bottle, and only because they didn't have another), the other I just swapped. I couldn't tell if they were genuine or aftermarket. =^..^=
          • sparkycivic
            • Apr 2017
            • 348
            does it say that the bottle is "full", or "almost full"? There are two different sensors involved with those readings.
            • Jhn16
              • Sep 2019
              • 7
              Clean properly the waste toner botle especialy the white plastic for waste toner box
              • JR2ALTA
                • Feb 2010
                • 2033
                Are you sure it wasn't an old bottle that was emptied? This can be done but the neck of the bottle needs to be spotless. A light sensor shines through the neck of the bottle and a little bit of toner will trip it. Also spray air in the machine section where the light would be.
                Red Lines represent ligth sensor path.
                  • 16416
                  Yeah, if you look closely there's 2 little windows on each side of the neck of the bottle.
                  • sparkycivic
                    • Apr 2017
                    • 348
                    it had popped out of the hole in the side of the bottle =^..^=
                    With strong hands and total disregard for skin and flooring, the top of the bottle - auger and all comes off, so the auger can be reset in the hole.
                    • Tonerkiller
                      • Oct 2012
                      • 668
                      I think it is a connector issue. Look to see if one of the pins were pushed in.
