TA 7002i Service Code C7460
  • Hoosierdaddy
    • Oct 2016
    • 181
    Upon arriving to call found DV lever Locked
    Unlocked and Reset Code. No luck still same code. Init. memory and still no luck. Could having the DV lever locked damaged something to cause this Service Code? Or any other insite would be appreciated. Thanks in advance. Also would someone be able to send me the Service-Parts Catalog
    Hoosierdaddy
    • 22999
    Re: TA 7002i Service Code C7460
    Look for a bent pin at the toner hopper relay connector, pin 15 (top pin), goes to developer shutter sensor DEVSS.
    The lock should be "in" and slide cover closed, not "out" with slide cover open. =^..^=
    • Hoosierdaddy
      • Oct 2016
      • 181
      Thank You for the reply I will check those 2 things.
