Quality issues M3550idn
  • and
    • Oct 2011
    • 96
    I have a M3550idn random make light prints.
    Replaced developer unit, drum unit, transfer roller, HV board and developer clutch.
    Thanks for any help.
  • mita
    • Sep 2010
    • 87
    Re: Quality issues M3550idn
    Are you using brand toner?
      Is it doing the same thing on print and copy?
      I can't tell a whole lot from the image you posted. Can you post a solid black image (skyshot)?
      • and
        • Oct 2011
        • 96
        OEM toner
        at the moment every print/copy exit good
        sky.pdf
          • 22997
          What is the interval on the anomalies crossfeed, as seen in the skyshot?
          My Acrobat Distance Tool tells me the interval is 45.212mm, which is the developing unit fault. If you've already changed the developing unit and clutch, I'd look at the rest of the developing drive components (gears, bushings, shafts, etc.). On the ECOSYS FS4020 I've seen those bushings oval out, and if I remember correctly, they are not available separately. I dug through my miscellany for bushing replacements.
          Keep in mind that every Kyocera monochrome desktop has defects of this sort, even new out of the box. =^..^=
          • sparkycivic
            • Apr 2017
            • 348
            Is the transfer roller assy fully seated, and clear of any debris in it's vicinity?
            • ntbann
              • Jan 2012
              • 627
              I had a transfer roller swell on one end causing light prints down one side.
              • Lync
                • Feb 2016
                • 47
                Looks like the drum has been exposed to light for too long.
