TASKalfa 6501i
  • rvptor
    • Aug 2018
    • 19
    TASKalfa 6501i
    Hello everybody,
    I have problem on TASKalfa 6501i, when I want to copy/scan something longer than 3 pages, every forth page is black on one side from document feeder. Maybe some service bulletin or ?
    Thanks in advance
  • sparkycivic
    • Apr 2017
    • 348
    Re: TASKalfa 6501i
    Perhaps hit the machine with a non-turbo firmware pack, and then go through all the connections of the DP especially the hinge area.
    Are you working from single or double sided originals?
    When you say "black on one side" do you mean, left vs right, or front vs back?
    Do the scan lamp(s) remain on and bright during the operation?
    are there any delays while feeding the pages?
      • 22999
      Re: TASKalfa 6501i
      Sample? =^..^=
      • Santander
        • May 2009
        • 768
        Re: TASKalfa 6501i
        Originally posted by rvptor
        Hello everybody,
        Thanks in advance
        Since you state that it happens on copy and scan you can eliminate the print engine, it is a scan problem. Since the 6501i has a dual scan DP it is important to know if this is happening when scanning one sided or two sided, two separate scanners. When you say that every fourth page is black on one side are you duplex printing/copying? A little more clarification on the job process would help.
