CS 3553ci - PinPoint Scan disappearing from homescreen frequently
  • daviek
    • Jan 2021
    • 2
    It seems about every week or so, PinPoint Scan disappears from the homescreen and homescreen settings of our customer's machine. It remains installed and listed under the applications setting... We fix this by going to the applications setting, deactivating and reactivating the license; it reappears on the homescreen. It works as a temporary fix, but every 1 to 2 weeks, it happens again. The firmware is up to date. I have no clue would could be causing this. Any help is appreciated! Thanks.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1876
    Re: CS 3553ci - PinPoint Scan disappearing from homescreen frequently
    Disabling the motion detection under system menu>System & Network settings will resolve it.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • daviek
      • Jan 2021
      • 2
      Interesting. Has this worked for you? I'll be trying it and see if it works.
      • Scott
        • 196
        Wow any reason as to why this happens??? We are seeing this as well
        • tmaged
          • Oct 2008
          • 1876
          It's a known issue and yep, it's worked for me. I assume it will be fixed in firmware at some point.
          Hope that helps !
          -Tony
          www.dtios.com
