Copying data from one machine to another
  • shelby1018
    • Jun 2014
    • 3
    [Misc] Copying data from one machine to another
    Client currently has a ta-8001i and we are upgrading them to a ta-8003i next week. They have around 400 job accounting accounts in the machine. Does anybody know if sim 917 will work to export and import. I know it usually has to be the same model machines for this to work. Not sure if there is a way to do an export from sim 917 on the new machine and do a cut a paste of the data from the old machine and then do an import? Just trying to make it easier than having to manually input all the accounts. Any help would be greatly appreciated. TIA
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Copying data from one machine to another
    Export with 917. Use the Setup Tool to convert it to the correct model. Import on new machine. Only address book, one touch and account codes will convert.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 30303
      You can also use KMNET Viewer with Accounting to copy and save as a file. Then reupload to new machine.
      If you can put both online you should be able to also transfer the data.
      You would have to ask Kyocera if the 917 will work it may use the same language.
      • Brianneoe
        • May 2015
        • 322
        Make sure you have the newest version of the set up tool. Older versions won't show the 03 series.
        • bronco31
          • Aug 2009
          • 174
          if its same as it used to be.. man is the setup tool clunky ! half the time i couldnt get it to work and not intuitive at all
          • dickierock
            • 252
            Hi,
            I would appreciate if someone can point me to the setup tool for moving the job accounting or a version of Net Viewer with the Job accounting add-on.
            Can't seem to find it, cheers.
            • MarcoKyo
              • Nov 2019
              • 9
              Hello,
              Normally the KM Net Viewer is on the dvd delivery with the device.
