3552ci missing color fyi
  • sparkycivic
    • Apr 2017
    • 348
    I wanted to throw this out there, an experience from last week.
    3552ci suddenly stopped printing yellow with no error codes except hidden C7620 and C7614(auto cal/registration). We went through the whole darn machine looking for obvious failures that could do this without coding, such as primary transfer inside the belt, HV contacts, developer, drum/dv drive, transfer HV, imaging HV, but after all that, it turned out to be a dead laser diode inside the common LSU, that somehow didn't cause any laser BD or stabilization codes!
    If I had to go to a call like this again, I'd put a strip of scotch tape on the charge roller and check for a heavy yellow stripe on printouts which is a much faster way to prove that all the rotating and HV systems are working, a tip I learned about late in the process of this call unfortunately!
    • 23010
    Re: 3552ci missing color fyi
    It sounds like you worked for that one. You don't see many failed laser units on Kyocera.
    Thanks for sharing. =^..^=
    • tsbservice
      Field tech
      • 8064
      Interesting. Do the Kyo have 4 laser diodes inside common laser unit? I know KonicaMinoltas have 1 diode or maybe 2 on faster devices.
      Good info though. I would also think it will code out.
      • sparkycivic
        • Apr 2017
        • 348
        Interesting. Do the Kyo have 4 laser diodes inside common laser unit?.
        Starting with the 02/52 series, the laser scanning section has been unified into a single part with either1 or 4 laser diodes mounted to a little circuit board on the side, a single BD sensor on it's own tiny board, a single ordinary polygon motor, and a whole lot of lenses/mirrors.
        • sparkycivic
          • Apr 2017
          • 348
          Our branch can go for years without changing a KYO laser, but we had a 5002 (which gave a LSU code), and this 3552ci within about a week of each other!
          • bronco31
            • Aug 2009
            • 174
            whats BD again? (its on the tip of my brain)
            • tsbservice
              Field tech
              • 8064
              BD=beam detect.
