TA3252ci & IB-51
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    TA3252ci & IB-51
    Connectd an IB-51 wireless card to a TA3252ci. It works as a printer but will not email.
    I have switched to use "Optional Wireless card" but still will not work.
    When testing an email, I get error 2101.
    I logged into the card and set the Maintenance settings for email, but still nothing will come through.
    Any ideas?
  • nathicana
    • Aug 2008
    • 332
    Re: TA3252ci & IB-51
    Any ideas?
    You may have done this but check that Primary Network is set to optional network
    • CWP
      • Jun 2013
      • 168
      I don't think that is within the IB-51's capabilities. Why don't you remove the IB-51 and try using the built in wireless for this model (IB-36 type) that has full functionality? I think when you switch the system settings to use the WiFi it is trying to route through the built in WiFi and not the IB-51. The IB-51 web interface is quite wonky and appears to be manufactured by someone other than Kyocera while the built in wireless is all the same CCRX.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1880
        I always use a $30 wireless bridge if the short range wireless won't work. The IB-51 has been available for like 6-7 years and hasn't been updated at all.
        I've beenusing this one lately and it's pretty good:
        https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • ATSBMCO
          Technical
          • Oct 2007
          • 70
          Hi,
          thanks for the messages.
          We gave up on the IB 51 and just used a wifi powerline plugin instead.
          Far simpilar.
