error code kyocera fs 3900 dn
  • Giafar Cv
    • Aug 2025
    Hello guys. i need help. I have got a printer kyocera fs 3900 that show following code: 150: 0011750. Someone can help me? Thank you
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1891
    150 is the error. It means the eeprom communication trouble. If powering off doesn't clear, you'll probably have to call a tech.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Giafar Cv
      Thank you for your answer. I try to power off but machine not working. I must be call a technician or i can reset error?
      • tmaged
        • Oct 2008
        • 1891
        Either the eeprom chip is not installed or the board is bad.
        Hope that helps !
        -Tony
        www.dtios.com
        • leroyal
          Expert on The Obsolete
          • Sep 2007
          • 156
          You need a service tech to update the firmware
          I know what I know better than anyone else knows what I know.
          • TheOwl
            • Nov 2008
            • 1732
            You definately need to update the firmware.
            If you do a search for "Error 150" you should see all the other threads that have been posted in regards to this problem. There is a lot of information that could help you.
            • Giafar Cv
              printer working now
              Thanks owl, i doing update firmware and the printer working now. Thanks guy for valuables suggestions. Indeed.
              • TheOwl
                • Nov 2008
                • 1732
                One other thing for you to check is to make sure that the Network card and the printer recognise the MAC address and serial number.
                Print out a service status page and check that they are both there.
                Menu - Others - Service - Status Page - Enter - Enter
                If they aren't there, then you might need to get a tech (unless you can find a copy of LPT Secure) to run LPT Secure through the machine to recover these bits of information.
